I'd like to add an 8 Terabyte drive.
So does that mean it will never work? Dont know how to interpret your comment. Thanks for the reply.This entry-level model with MediaTek MIPS 880MHz CPU and 256MB RAM is perhaps the worst place you can plug your USB HDD into.
Many other posts are mentioning HFS+ as being supported by Asus, so this is not the case?You have to reformat the drive to standard NTFS. The speed to/from this HDD will be slow and your router's main duties may suffer due to low specs hardware.
The drive is not encrypted. I will acquire a seperate HDD to make a copy of the data and then reformat. Thank you for the replyThere's a note in the Asus FAQ that HFS+ encrypted drives are not supported. Is your drive encrypted by iOS?
Can you copy your data elsewhere, reformat the drive as NTFS (verify that it now mounts OK) and then copy the data back?
Its possible HFS+ may not be supported on that router. The English User Manual for the RT-AX1800U does not appear to mention HFS+, rather it states the following on page 24 under Monitoring your USB device:I just bought ASUS RT-AX1800U and was hoping to connect my 4TB WD passport to it. It has HFS+ and not partitions.
Copy the data, if any, off the drive and reformat the hard drive to NTFS. Then connect the drive to the router and see if it's recognized.The wireless router works with most USB HDDs/Flash disks (up to 2TB size) and supports read-write access for FAT16, FAT32, EXT3, and NTFS.
I had read through everything I thought. Thank you! Would it be enough to just make a partition with 2TB? Or would it have to be a HDD with no more than 2TB?Its possible HFS+ may not be supported on that router. The English User Manual for the RT-AX1800U does not appear to mention HFS+, rather it states the following on page 24 under Monitoring your USB device:
Roger, I will try thatYou can try with full 4TB capacity first. If not recognized - shrink the partition to 2TB and try again.
Not sure what you need this drive attached to the router for. Make sure you always have a second copy of your valuable data.
Start with a single partition the full size of the hard drive and format it for NTFS. Then connect it to the router and see if it's mounted and seen by the router. If so then try using it. If not then repartition the hard drive to 2 x 2TB partitions both formatted for NTFS and reconnect to the router and see if mounted and recognized.Would it be enough to just make a partition with 2TB? Or would it have to be a HDD with no more than 2TB?
NTFS is best if there's problems. The drive can be accessed directly by both windows and Linux machines. Windows won't see an ext3 partition without some fiddling.Why always "format it with NTFS" and not EXT3 (since that's what's native to the router)? I guess maybe I could better understand it if the advisee was a Microsoft sufferer, but this time at least it appears not the case...
Basic troubleshooting step and for compatibility reasons. If one isn't using Asus-Merlin firmware then using the stock Asus firmware to format the USB drive may limit them to NTFS or FAT (or on certain routers HFS). EXT may not be a format option on stock Asus firmware even though the firmware may support externally EXT3 or EXT4 formatted hard drives. If the drive is properly seen and mounted and one is using Asus-Merlin firmware then one can decide if they want to reformat the drive using EXT4 via AMTM.Why always "format it with NTFS" and not EXT3 (since that's what's native to the router)? I guess maybe I could better understand it if the advisee was a Microsoft sufferer, but this time at least it appears not the case...
Welcome To SNBForums
