GT-AXE11000 WiFi 6E SSID is showing as 5GHz band and a/n/ac mode in scanners
s814jdh
There are so many options when configuring the radios on the GT-AXE11000 and I can't figure out what is going on. I have gone through documentation to try and understand all the options, but I haven't found the magic combination that makes this work. Hoping someone here in the forum can solve the puzzle and educate me on what I am doing wrong.
Not sure if it plays a role, but my GT-AXE11000 router has an RT-AC5300 router connected as an AI Mesh node using an Ethernet backhaul. The GT-AXE11000 has merlin firmware 3004.388.8_4 installed. The RT-AC5300 has merlin firmware 3004.386.14_2 installed.
Here is the basic configuration of the SSIDs:
Here are the Professional settings for each band:
Scanning tools like WiFi Explorer and NetSpot show my WiFi 6 SSID in the 5Ghz band with an a/n/ac mode instead of ax.
Network Name: HARMON24
Vendor: ASUSTeK Computer Inc.
Annotations:
Signal: 75%
Channel: 1
Channel Width: 20 MHz
Band: 2.4 GHz
Mode: g/n/ax
Generation: 6
Security: WPA2 (PSK)
Max Rate: 573.5 Mbps
Seen: 2024/12/05 11:05:59 AM
Annotations:
Signal: 67%
Channel: 1
Band: 2.4 GHz
Mode: b/g/n
Generation: 4
Max Rate: 288.9 Mbps
Network Name: HARMON50
Annotations:
Signal: 58%
Channel: 149
Channel Width: 80 MHz
Band: 5 GHz
Mode: a/n/ac/ax
Generation: 6
Max Rate: 2402 Mbps
Annotations:
Signal: 48%
Channel: 36
Channel Width: 40 MHz
Band: 5 GHz
Mode: a/n/ac
Generation: 5
Max Rate: 800 Mbps
Network Name: HARMON_6G
Annotations:
Signal: 46%
Channel: 149
Band: 5 GHz
Mode: a/n/ac
Generation: 5
Max Rate: 1733.3 Mbps
The only thing connecting to the WiFi 6 SSID (HARMON_6G) is my iPhone 15 Pro Max. Shouldn't I see the SSID using the 6Ghz band? Why isn't it running in ax mode?
I think I have figured it out. I under estimated just how much the 6G signal cannot get through walls. If I take a laptop and sit it within feet of the router I see the signal in the 6GHz band in ax mode. Until I get some mesh nodes that can broadcast that 6Ghz signal, the 6GHz is useless in my 2,000 square foot house.
