mighty_scoop
Hi together,
2 month ago i bought a GT-AXE16000 with a Zen ET12 as an AI-Mesh client.
Everyday there are ~3-5 (internet) crashes and i first thought it was because of my provider.
After checking my internet connection (with another router) i started to "investigate".
I've found this in the systemlogs (at a time where my system crashed):
Oct 12 21:02:34 bsd: bsd: Skip STA:ee:41:d6:a5:0e:2a reject BSSID
Oct 12 21:02:41 kernel: F8:77:B8:2C:FA:E5 not mesh client, can't delete it
Oct 12 21:02:44 bsd: bsd: Sending act Frame with transition target eth10 ssid a0:36:bc:61:4b:b4
Oct 12 21:02:44 bsd: bsd: BSS Transit Response: ifname=eth8, event=156, token=e4, status=6, mac=34:0d:62:42:1a:b7
Oct 12 21:02:44 bsd: bsd: BSS Transit Response: STA reject
Oct 12 21:02:44 bsd: bsd: Skip STA:ee:41:d6:a5:0e:2a reject BSSID
Oct 12 21:02:47 kernel: eth5 (Int switch port: 6) (Logical Port: 6) (phyId: 13) Link DOWN.
Oct 12 21:02:47 kernel: ^[[0;34m[NTC xport] xport_reset: rc = 0; intf = 3 port = 2 spd = 2.5G dup = 1
Oct 12 21:02:47 kernel: ^[[0m
Oct 12 21:02:47 kernel: br0: port 5(eth5) entered disabled state
Oct 12 21:02:52 kernel: ^[[0;34m[NTC xport] xport_init: rc = 0; intf = 3 port = 2 spd = 2.5G dup = 1
Oct 12 21:02:52 kernel: ^[[0m
Oct 12 21:02:52 kernel: eth5 (Int switch port: 6) (Logical Port: 6) (phyId: 13) Link Up at 2500 mbps full duplex
Oct 12 21:02:52 kernel: br0: port 5(eth5) entered blocking state
Oct 12 21:02:52 kernel: br0: port 5(eth5) entered listening state
Oct 12 21:02:54 kernel: br0: port 5(eth5) entered learning state
Oct 12 21:02:54 bsd: bsd: Sending act Frame with transition target eth10 ssid a0:36:bc:61:4b:b4
Oct 12 21:02:55 bsd: bsd: BSS Transit Response: ifname=eth8, event=156, token=e5, status=1, mac=dd:07:50:6f:9a:16
Oct 12 21:02:55 bsd: bsd: BSS Transit Response: STA reject
Oct 12 21:02:55 bsd: bsd: Skip STA:ee:41:d6:a5:0e:2a reject BSSID
Oct 12 21:02:56 kernel: br0: port 5(eth5) entered forwarding state
Oct 12 21:02:56 kernel: br0: topology change detected, propagating
Oct 12 21:03:05 bsd: bsd: Sending act Frame with transition target eth10 ssid a0:36:bc:61:4b:b4
Oct 12 21:03:05 bsd: bsd: BSS Transit Response: ifname=eth8, event=156, token=e6, status=6, mac=34:0d:a0:36:bc:61
Oct 12 21:03:05 bsd: bsd: BSS Transit Response: STA reject
Oct 12 21:03:05 bsd: bsd: Skip STA:ee:41:d6:a5:0e:2a reject BSSID
Oct 12 21:03:09 dnsmasq-dhcp[3176]: DHCPREQUEST(br0) 192.168.50.6 c8:ff:28:47:b3:c3
Oct 12 21:03:09 dnsmasq-dhcp[3176]: DHCPACK(br0) 192.168.50.6 c8:ff:28:47:b3:c3 TRON
Oct 12 21:03:09 kernel: C8:FF:28:47:B3:C3 not mesh client, can't update it's ip
Oct 12 21:03:12 dnsmasq-dhcp[3176]: DHCPREQUEST(br0) 192.168.50.6 c8:ff:28:47:b3:c3
Oct 12 21:03:12 dnsmasq-dhcp[3176]: DHCPACK(br0) 192.168.50.6 c8:ff:28:47:b3:c3 TRON
Oct 12 21:03:15 bsd: bsd: Sending act Frame with transition target eth10 ssid a0:36:bc:61:4b:b4
Oct 12 21:03:16 bsd: bsd: BSS Transit Response: ifname=eth8, event=156, token=e7, status=1, mac=dd:07:50:6f:9a:16
Oct 12 21:03:16 bsd: bsd: BSS Transit Response: STA reject
Oct 12 21:03:16 bsd: bsd: Skip STA:ee:41:d6:a5:0e:2a reject BSSID
Can anybody help me?
I am using the newest (non-beta) firmeware for both asus devices.
Thanks in advance,
Dominic
Thanks in advance,
Dominic
