GT-BE98 Pro AiMesh with GTAXE16000 Lan/Wifi random dropouts
bounceb2
I currently have a GT BE98 PRO downstairs which is hardwired to my AXE16000 upstairs and I have noticed the randomly freezing wired and connection dropping on wifi and then reconnecting back within a minute or so. The lights on the AXE16000 dont seem to change as I mostly notice it in browser on hardwire desktop or on a wireless voip phone. Are there any settings or anything that I may need to check that can help? I figured maybe if tried the Merlin firmware that it may help but it still looks like i'm still having similar issues. If it was only the wifi portion I would think it was specifically the wifi settings but the ethernet connection does the same. Thank you for your time.
I figured that there's a limitation on BE98 Pro router with MLO enabled.
When you add GT-AXE16000 as an AIMesh node, if MLO is enabled on AiMesh Primary router, the node (AXE16000) without MLO will not broadcast 6GHz. WiFi. To enable 6Ghz, then you need to disable MLO, please go to: http://www.asusrouter.com/MLO.asp
I mentioned in my post here: https://www.snbforums.com/threads/a...vailable-for-wifi-7-devices.90788/post-917550
I have the same issue with my GT-AXE11000, and MLO IS disabled. 6GHz still does not broadcast. So it's not related:
