New Asus GT-BE98 Pro, Firmware:3006.102.2. Fresh install and setup, no import of settings. After configuration there was a default wifi network named "Default IoT Network" that I did not have to configure, and has very few configuration options. Only SSID and password. I used this wifi network and discovered that I can still access all hardwired devices on the network.
I then configured a "customized network" for IOT devices that I want internet access only, no intranet access. I have configured and disabled "access intranet" and also tried the setting "Set AP Isolated"option. No matter what I try, if I connect to this wifi network I can still access all devices on the network, not just the created wifi network. I am new to Guest Network Pro and am unsure if it is a bug or if I am missing something like creating VLans first or something. I was using YazFi on a previous router and everything worked wonderfully. Ive read through Asus documentation and it seems like it should be as easy as using the slider to disable or enable "access intranet".
