Guest Account ?
Techno
I apologize in advance for the stupid question...I just recently installed the newest version of Merlin and I added a guest account for visitors but I only see an option to "Remove" account instead of being able to modify it and disabled it for a period of time. I would like to modify it to disable it and then enable it when I see fit instead of recreating the account when needed.
Am I missing something...?
Thanks for any assistance you can provide....
Are you referring to disk sharing? If yes, then accounts cannot be edited, only removed.
No not disk sharing....definitely Guest Network config...I have everything loaded SSID, password, etc but the only option below the configuration in a red box is "Remove". I always thought there was a way to just disable it instead of completely remove. I can get a screen shot if needed?
Removing a Guest Network is the same as disabling it, i.e. settings are still kept in nvram.
