Hi everyone,
I installed Merlin on two new RT-AC87U which will cover my house to replace my aging DLink routers.
One will be in router mode and the other will be in AP mode. One thing I hoped to get working with the Merlin firmware was roaming guest networking between the devices whilst keeping the intranet out of reach from devices on the guest network.
However, I have hit a dead end with trying to get this working. I know on my existing DLinks that all guest network traffic is forcibly routed out of the WAN interface which is not helpful when I have an ethernet trunk running between the two routers on their LAN interfaces.
Given the write ups on Merlin, I had hoped to change the networking configurations on the Access Point ones to bridge / route the guest networks (2.4 and 5Ghz) over the LAN trunks I have and out via the one in Router mode. When going through the interface, robocfg, vlan and bridge configurations, they were terribly misleading (especially coming from a Linux networking background) and am in need of some help. One thing I noticed also that setting the device into AP mode and configuring the guest wireless, the guest networks (both 2.4 and 5Ghz) can access the local network which is obviously not supposed to be able to happen.
If I can get it to work, I will purchase another to replace the 3rd DLink I have (the second one in AP mode on the diagram below).
Here is what my network looks like:
Any help is very much appreciated!!
P.
Hi everyone,
| ISP router |
| wan: <ISP ip> |
| lan: 192.168.10.254 |
| lan1
| w
| RT-AC87U (router mode) |
| wan: 192.168.10.1 |
| lan: 192.168.1.1 |
| 2.4ghz: net24 |
| 5ghz: net5 |
| guest 2.4ghz: guest24 |
| guest 5ghz: guest5 |
| lan1 | lan2
| lan1 | lan1
| RT-AC87U (AP mode) | | RT-AC87U (AP mode) |
| lan: 192.168.1.2 | | lan: 192.168.1.3 |
| 2.4ghz: net24 | | 2.4ghz: net24 |
| 5ghz: net5 | | 5ghz: net5 |
| guest 2.4ghz: guest24 | | guest 2.4ghz: guest24 |
| guest 5ghz: guest5 | | guest 5ghz: guest5 |
P.
