I'm trying to setup some more 'guest' wifi's on my RT-BE88u.
I have setup the default IOT guest wifi which works fine, except you cannot eg. disable 5Ghz.
Thus I wanted to created a new IOT guest wifi network, with settings I want. But after creating it, it is not visible. Even when I scan the 2D barcode, I cannot connect.
Played around with same subnet, and access intranet, but no luck.
Anyone having ideas?
