Guest network - Running a script on enable/disable
SteveM
I’m trying to work out how to run a script when the guest WiFi network is enabled or disabled.
I’m thinking that I should be using the service-event-end script.
I think I should be looking for a wireless service for start/restart/stop but I could do with a pointer on how to detect the status of the guest networks.
Any help gratefully received.
