Is it possible to buy a Wireless Access Point that supports guest network access?
Basically I want to be able to provide guest access to the internet (with no security) for "foreign" mobile devices e.g. iPhones etc (we have teenagers with teenage friends!) but I also want to connect an internet radio device wirelessly that will also be able to stream from my NAS (QNAP TS-509), so this would need access to the LAN.
Although I have Cat 6 wiring in parts of the house, it does not extend to the kitchen where I want to put the internet radio (probably a Logitech SqueezeBox).
While I can set up a VLAN on my router (Netgear UTM5) to isolate the Ethernet port into which I can plug an AP, this would deny the internet radio access to my NAS. BTW - I am also running an HP 1810g-24 switch which also supports VLANs.
I guess I could run two APs - one isolated as above on a VLAN, and the other (with WPA security) for the internet radio on the LAN - but this seems excessive and costly.
Alternatively, could I use something like a Netgear WNDR3700 set up as an AP but retaining the guest network capability (I am thinking not, as this is a router function)?
Any ideas?
Any ideas?
