fusionstream
This is my network layout:
The DIR865L is running Tomato and the AC5300 is running the Christmas release of ASUSWrt by Merlin.
How would I go about vlanning guest wireless traffic from the Asus to the DIR865L?
Doing it on Tomato and the 2 managed switches should be trivial but not so much on the Asus.
I currently have physical ports 3 and 4 on the asus unused but I'd like to try trunking it over the existing LACPed physical ports 1 and 2.
I saw a few threads (specifically this one http://www.snbforums.com/threads/ssid-to-vlan.24791/) that seem to have this working but the internal port mappings don't match up and I can't find a port mapping list. Is there a way to get this?
Based on "robocfg show vlan it would seem that Port 8 is my 2.4GHz wireless (based on MAC address) and it shows that port 8 is in 2 vlans (I have 2 guest networks on 2.4GHz and only one of them can access my "intranet"). I assume vlan2 is the wan vlan and port 0 is my WAN port.
I can only assume internal Ports 5 and 7 are for my 2x 5GHz radios. They both have guest networks WITH access to Intranet. However when I added a guest network WITHOUT access to Intranet, nothing was added to vlan2. In fact, under "brctl show" this new guest network gets added to br0.
RT-AC5300-1DE0#:/tmp/home/root# brctl show
bridge name bridge id STP enabled interfaces
br0 8000.2c56dc5d1de0 yes vlan1
wl0.1
wl0.2
wl1.1
wl1.2
wl2.1
RT-AC5300-1DE0#:/tmp/home/root# robocfg show vlan
Switch: enabled
Port 0: 1000FD enabled stp: none vlan: 2 jumbo: on mac: 00:00:0c:9f:f4:ef
Port 1: DOWN enabled stp: none vlan: 1 jumbo: on mac: 00:00:00:00:00:00
Port 2: 1000FD enabled stp: none vlan: 1 jumbo: on mac: 00:24:1d:d1:f1:6c
Port 3: DOWN enabled stp: none vlan: 1 jumbo: on mac: 00:00:00:00:00:00
Port 4: DOWN enabled stp: none vlan: 1 jumbo: on mac: 00:00:00:00:00:00
Port 8: 1000FD enabled stp: none vlan: 1 jumbo: on mac: 2c:56:dc:5d:1d:e0
VLANs: BCM5301x enabled mac_check mac_hash
1: vlan1: 1 2 3 4 5 7 8t
2: vlan2: 0 8u
Can anyone help? A pointer would be great too as I'd like to understand what is happening.
wl0.1
wl0.2
wl1.1
wl1.2
wl2.1
Switch: enabled
2: vlan2: 0 8u
