Solved Hacked or not, doubtful but making sure
aex.perez
For the last few days my AX88u on 388.4 was acting weird and wierder every day. Changing the channels on 5Ghz WiFi often, way too often to be normal, 802.3d setting was disabling my NAS, 2.4Ghz devices were dropping of and no longer able to establish a connection. when it got worse I finally had to take action to "fix" things, thinking it would've been easy.
Probably would’ve been easier and faster to start from scratch, do a full reset, recover, reinstall of scripts, reboot and reestablish the mesh (ax86 node's) resetting the mesh nodes along the way. But I was curious mainly because I thought I had been hacked and was curious how with no services being exposed to the Internet it happened.
Then on further inspection scribe, Skynet, spdMerlin all stopped working, or would randomly stop performing their function. For example, Skynet stopped logging, even via the script's debug options. Scribe would report the configuration file was formatted wrong and failed to run. spdMerlin wouldn’t produce results when running a speedtest.
Then upon noticing the 5Ghz channel changing from the default I had configured and going into the configuration via the GUI. I could no longer pick the channel, just auto or a limited number of channels were available in the GUI, none that enabled 160Mhz bandwidth. Also certain channels numbers ending with an "I" did show up and allowed me to select them. Unless I picked 80Mhz then more channels would appear in the GUI but not all for the US region. Even 20/40/80/160Mhz didn't help.
Immediately going to the command line via ssh, I ran HTOP on the AX88 and AX86s nodes looking for any services running that shouldn’t be or abnormal CPU/RAM utilization. None were, all running were within my norms for my setup. Then I listed out NVRAM (nvram getall) on all devices making sure they were all set for the US. They were and even matched them against a copies I had stored previously, all good.
At which point I used BACKUPMON to run a restore for the router from a few weeks back. Uninstalled the scripts I referenced, then installed them fresh. Upon the scribe install none of the default filters came back/got installed, luckily the backup had a copy of them. Got those recovered eventually.
Did the restore, then rebooted a few times to get the scripts installed and the router and nodes up on the restored config. Changed the password on the router to be safe. Verified no open services exposed to the internet. Ran a GRCShieldsUp scan (amongst others) to verify nothing was open that should not have been. Also run a couple of malware tools on the PC, which also came up clean. Comparing results along the way to how things were before things started acting strange.
Once the router was booted and I was no longer getting errors about the NAS losing connectivity, devices on 2.4Ghz not dropping off (none showing as still connected but couldn’t be accessed, as before), 5ghz stable on the channel and 160MHZ bandwidth (32Hrs so far, where I was getting a channel change every 5min during this, and stable for months on end before that). The scripts all running, and the scribe filters restored. So far, the last 12 hours have been uneventful, so back to stability 🤞👍.
Some of this reminded me of the AiCloud issues recently reported but again, no open services on the router exposed to the internet, no changes in the amount of data uploaded/downloaded, nothing running that shouldn’t be on either the router or nodes, CPU utilization within my expected norms of Router and Nodes. Never had AiCloud (or anything else) running either. Region was still set to US. Also 388.4 installled on the router and nodes, and the Trendmicro signatures were current on the router and nodes.
Normally, at this point I’d be pointing the finger at hardware. But after restoring the configs, reinstalling the scripts from scratch, recovering the scribe filters, with the password change and reboots.
I’m left wondering if corrupted device RAM or the USB/SSDs could’ve caused these anomalies? But I would expect to still have problems if it was hardware related. As everything is back to the way it was and no longer seeing any anomalies I'm left wondering. Also note that the router is on a UPS and on filtered power in case the thought of a power spike might've had an influence.
Very happy that its all working again, nothing suspicious was found/identified running taking up CPU or abnormal uploads or bandwidth consumption during all of this or after. But still my doubts remain.
Nothing like looking a gift horse in the mouth as they say, but curiosity is eating away at me as to a possible cause.
Tried to be thorough, 🤷‍♂️
So what else should I be/have been looking for a root cause?
One possibility could be corrupted blocks in the nvram that was detected and automatically moved by the controller to good blocks but retained the corruption. Doing what you did would write to the good blocks.
Your first paragraph is symptomatic of low power delivery to the AP. AP radios can be sensitive to insufficient power delivered. Replacing the wall wart power block can fix that issue.
Low power delivery can also explain the memory corruption. If you have a new wall wart, i would just replace the existing especially if more than a few years old. Does the block feel warm or temperate/cool to touch ?
How old is the UPS ? What is the switching time or has it been through a power droop and picked up in time to maintain the network ?
Some UPS , in effect, rely on the PC power supply capacitors to hold minimum voltage while they switch as they are not running through the battery. Saves the battery though.
NVRAM corruption I considered that as the Router's integrated switch and LAN 802.3d settings and the NAS were acting up. With WiFi devices connected but unable to be accessed being another sign of that (should have checked the ARP table). Still running the same Ethernet cables, and its working, and staying up now.
UPS is fine, stays up and warns even with a slight flicker (which doesn't happen often since FPL, the power company's recent line maintenance, I'm blocks from the substation). It's cool to the touch, as well as the Router temps (stable +/-1°C, 2.4 GHz: 41°C - 5 GHz: 41°C - CPU: 59°C) well within norms, which I looked at to make sure it wasn't overheating. Was thinking heat, more than power as I was looking for things that might've contributed to this.
The Router and the modem are on one UPS, PC is another. Nodes were fine throughout this mess, and are not on UPS, but again Nodes and I can recover them easily.
That said, Power is a good place to look, thinking the Router's power brick might be a contributing factor. The AX88 and AX86 have the same brick I believe, as the nodes were bought later and are a few months newer, from a use/operational perspective. I just may move those bricks around to see if/when it happens again I can then isolate it to particular device/power brick.
I can't say exactly when it starting acting up, but I suspect it started about a week ago just after setting up the new doorbell cam. It took a while for me to treat this as one event vs. several Isolated events, but when the events started piling up and happening consistenly and with greater frequency, I had an "Aha!" moment. I started to treat them as indicitive of a broader problem. That's when I ran into the config and script issues and thought, hack!. But didn't want to make that conclusion without some homework and documented proof.
So far, still running normally this morning. NAS connectivity has stayed up as well as all the devices, all MACs accounted for, WiFi channels stayed the same, and bandwidth (stays on 160Mhz), all scripts active and working, and BACKUPMON kicked off and completed on all three as scheduled, all other cron jobs ran/are running as well.
Back to my Normal!
