i’m running a RT-AC5300 router downstairs with a RT-AC66u in bridgemode in the attic
Both have 5gh configured in 80mhz AC only and run great.
Throughput is 200Mbps on both running Merlin 380.68-4
The 5300 has the 2 5gh channels combined. The 5300 and 66 have different ssids.
The “problem” I’m facing is that roaming doesn’t work flawless, often when going upstairs the client sticks to the 5300 wifi, even with barely no signal
When you switch manually to the 66 everything runs great. Sometimes roaming works after 30secs sometimes 5mins, sometimes not at all. Manual switching always works instantly.
The same behaviour happens the other way around, going downstairs. Even with the most fragmented signal it hangs on to the 66.
I do realise this is a “1st world problem” but I would just like this to work more CONSISTENT and FASTER than manual switching.
We’re talking all AC apple devices here, ipads, iphones, MBP, so nothing to be tweaked on the client side
To be clear this has nothing to do with throughput or clients dropping of or 5gh bands dissapearing. Manually it all works great, I just want flawless roaming as well. Any suggestions?
