Hardware issue? Error log
Zim
Have been having problems with my router for about a week, where the router randomly locks up and DNS queries are not being resolved.
I thought it might have been related to a recent update to AGH. I tried uninstalling, reinstalling AGH. Went through several reset, reconfigure cycles, but the problem remained.
Today I'm seeing some errors in logs, I have no idea what they mean. Digging around the forum, some threads are mentioning it maybe related to TrendMicro. I currently don't have TrendMicor enabled. I did enable it to try it out about a week ago (incidentally, it coincided with the AGH update), but over the last week I've reset the router a few times and have not enabled TrendMicro.
In the logs I see normal activity like DHCP assigning IPs, handshakes then the router froze for about 10 minutes then I see the errors below then it goes back to DHCP assigning IPs, handshakes etc.
Is this a hardware issue? Should I reflash the original firmware and then reflash the Merlin firmware? Appreciate any help and guidance in troubleshooting this.
Mar  8 kernel: potentially unexpected fatal signal 11.
Mar  8 kernel: CPU: 1 PID: 2972 Comm: conn_diag Tainted: P           O      4.19.183 #1
Mar  8 kernel: Hardware name: GTAXE16000_2GB (DT)
Mar  8 kernel: pstate: 000f0010 (nzcv q A32 LE aif)
Mar  8 kernel: pc : 00000000f71a45c8
Mar  8 kernel: lr : 00000000f71a469c
Mar  8 kernel: sp : 00000000f7049980
Mar  8 kernel: x12: 00000000f71bc108
Mar  8 kernel: x11: 00000000f6b1c66d x10: 0000000000000000
Mar  8 kernel: x9 : 00000000f71bc000 x8 : 00000000ffe57b3e
Mar  8 kernel: x7 : 00000000f7ab435b x6 : 00000000f6b24d00
Mar  8 kernel: x5 : 00000000f70499b4 x4 : 0000000000000000
Mar  8 kernel: x3 : 00000000f6b23e28 x2 : 00000000f6b24d00
Mar  8 kernel: x1 : 00000000f71bc188 x0 : 0000000020657661
Mar  8 kernel: CPU: 3 PID: 2966 Comm: conn_diag Tainted: P           O      4.19.183 #1
Mar  8 kernel: pstate: 80830010 (Nzcv q A32 LE aif)
Mar  8 kernel: pc : 00000000f71a4820
Mar  8 kernel: lr : 0000000000000002
Mar  8 kernel: sp : 00000000ffe57330
Mar  8 kernel: x12: 0000000000000001
Mar  8 kernel: x11: 0000000000000000 x10: 0000000000200000
Mar  8 kernel: x9 : 0000000067cbe53d x8 : 0000000000000000
Mar  8 kernel: x7 : 000000000024f13c x6 : 00000000f71bc188
Mar  8 kernel: x5 : 0000000000000000 x4 : 00000000fffffff8
Mar  8 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Mar  8 kernel: x1 : 0000000000000000 x0 : 00000000f6b240c0
Did you withdraw from Trendmicro on the privacy page?
Yes, the privacy page is blank - Asus and TrendMicro have no permissions.
Curious if anyone can explain what wl3.2 refers to?
Mar  8 hostapd: wl3.2: STA xx:xx:xx:xx:xx:xx IEEE 802.11: disassociated
Mar  8 hostapd: wl3.2: STA xx:xx:xx:xx:xx:xx IEEE 802.11: associated
All of today, whenever the router has locked up, I've checked the logs immediately after and this code ALWAYS comes up whenever the router locks up.
You have a fourth WiFi band/network (possibly the 6GHz band or fourth radio in the router). Those log entries, if they have the same MAC address, are indicating a WiFi device has disconnected and reconnected.
Got it! Thanks for explaining.
I noticed that my devices connected to Guest Network weren't getting internet. I restarted the Guest Network and the router has been running happy for 12+ hours. No disconnects, no error logs!
