Nov 19 19:54:21 kernel: xhci_hcd 0000:00:0c.0: WARN: short transfer on control ep
Nov 19 19:54:21 kernel: xhci_hcd 0000:00:0c.0: disable burst on ep 1
Nov 19 19:54:21 kernel: xhci_hcd 0000:00:0c.0: WARN no SS endpoint bMaxBurst
Nov 19 19:54:21 kernel: xhci_hcd 0000:00:0c.0: disable burst on ep 2
Nov 19 19:54:22 kernel: scsi 0:0:0:0: Direct-Access Intenso External USB 3.0 0006 PQ: 0 ANSI: 6
Nov 19 19:54:22 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Nov 19 19:54:22 kernel: sd 0:0:0:0: [sda] 732566646 4096-byte logical blocks: (3.00 TB/2.72 TiB)
Nov 19 19:54:22 kernel: sd 0:0:0:0: [sda] Write Protect is off
Nov 19 19:54:22 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Nov 19 19:54:31 kernel: sd 0:0:0:0: [sda] 732566646 4096-byte logical blocks: (3.00 TB/2.72 TiB)
Nov 19 19:54:31 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Nov 19 19:54:31 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Nov 19 19:54:31 usb: USB /dev/sda1(ntfs) failed to mount At the first try!
Nov 19 19:54:33 usb: USB ntfs fs at /dev/sda1 mounted on /tmp/mnt/INTENSO.
Nov 19 19:54:34 rc_service: hotplug 766:notify_rc restart_nasapps
Nov 19 19:54:34 iTunes: daemon is stopped
Nov 19 19:54:34 FTP Server: daemon is stopped
Nov 19 19:54:35 Samba Server: smb daemon is stopped
Nov 19 19:54:35 kernel: gro disabled
Nov 19 19:54:35 Timemachine: daemon is stopped
Nov 19 19:54:35 kernel: gro enabled with interval 2
Nov 19 19:54:36 Samba Server: daemon is started
Nov 19 19:54:44 kernel: tntfs error (device sda1, pid 801): ntfs_end_buffer_async_read(): Buffer I/O error, logical block 0xc0005.
Nov 19 19:54:44 kernel: tntfs error (device sda1, pid 801): ntfs_mft_record_map(): Failed to map page containing mft record 0x5 (error 5).
Nov 19 19:54:44 kernel: tntfs error (device sda1, pid 801): ntfs_mft_record_map(): Failed with error code 5.
Nov 19 19:54:44 kernel: tntfs error (device sda1, pid 801): ntfs_write_inode(): Failed (error 5). Run chkdsk.
Nov 19 19:54:44 kernel: tntfs error (device sda1, pid 801): ntfs_bio_end_io_write(): Bio write I/O error.
Nov 19 19:54:44 kernel: tntfs error (device sda1, pid 801): ntfs_end_buffer_async_read(): Buffer I/O error, logical block 0xc003c.
Nov 19 19:54:44 kernel: tntfs error (device sda1, pid 801): ntfs_mft_record_map(): Failed to map page containing mft record 0x3c (error 5).
Nov 19 19:54:45 hotplug[843]: USB partition unmounted from /tmp/mnt/INTENSO
Nov 19 19:54:45 rc_service: hotplug 843:notify_rc restart_nasapps
Nov 19 19:54:45 rc_service: hotplug 844:notify_rc restart_nasapps
Nov 19 19:54:45 rc_service: waitting "restart_nasapps" via ...
Nov 19 19:54:45 iTunes: daemon is stopped
Nov 19 19:54:45 FTP Server: daemon is stopped
Nov 19 19:54:46 Samba Server: smb daemon is stopped
Nov 19 19:54:46 kernel: gro disabled
Nov 19 19:54:46 Timemachine: daemon is stopped
Nov 19 19:54:46 kernel: gro enabled with interval 2
Nov 19 19:54:47 Samba Server: daemon is started
Nov 19 19:54:48 iTunes: daemon is stopped
Nov 19 19:54:48 FTP Server: daemon is stopped
Nov 19 19:54:49 Samba Server: smb daemon is stopped
Nov 19 19:54:49 kernel: gro disabled
Nov 19 19:54:50 Timemachine: daemon is stopped
Nov 19 19:54:50 kernel: gro enabled with interval 2
Nov 19 19:54:51 Samba Server: daemon is started
