Having some troubles with my NAS (Running OpenIndiana)
Jesse B
First things first, I have basically no experience with anything Solaris related. I'm quite familiar with Linux however.
I recently set up my server running OpenIndiana. It's installed to a random HD I had laying around, and I set up a ZFS mirror with my two Samsung F4's, giving me 2TB of redundant storage. I'm also running a couple VM's off this server temporarily using VirtualBox (web server and a media server), just until I build a proper virtualization/storage server.
Anyways, basically what I'm doing is just using OI for ZFS, and then I set up an NFS share for my media center VM (Ubuntu 10.10). I believe I have set things up properly, but I'm having permission issues whenever I try to download anything to the NFS share.
My mirrored pool is simply /data/. I created an NFS share for the directory /data/Media/, which contains a few folders within it for Music, Videos, etc. After reading a bit online, I appended my /etc/dfs/dfstab file in the following manner:
share -F nfs -o rw,root=192.168.0.111 /data/Media/
IP's are a bit weird because I'm not at home for awhile, but that's not important ;) Pretty much that IP is just my media server, simple enough. I created the directory /nfs on my Ubuntu media server, and ran the following command:
sudo mount 192.168.0.103:/data/Media /nfs
Where *.103 is my server. Basically I'm unable to create/add files to any of the directories within the NFS share. What am I doing wrong?
Thanks,
- Jesse
I'm no expert with NFS but I looked up the man pages for "share" and I think your command should be:
share -F nfs -o rw=192.168.0.111 /data/Media/
or
share -F nfs -o root=192.168.0.111 /data/Media/
or
Thanks for your input :)
I changed it to "share -F nfs -o root=192.168.0.111 /data/Media/", as well as just ran "chmod -R 777 /Data/Media/" and things seem to be working. The chmod was from before and was just temporary to see if I could get it to work, so I'll have to try it without that still. Regardless, NFS is working now.
One issue I'm having is the transfer speed however.
- I benchmarked my data pool at 107MB/s Write and 192.84MB/s read
- iPerf gave me consistent results of 942Mbit
I'm still only averaging about 17MB/s transfer speeds however. I'm not sure if this has to do with the bridged network adapter of the VM or what, but I was hoping to get things quite a bit higher than that. I've yet to try NFS on a separate Linux box, and I haven't installed Samba yet, so I still have some more testing to do.
Thanks,
- Jesse
How much memory do you have assigned to it?
Anytime I have played around with ZFS/Openindiana/nexentastor community edition the biggest limitation on my transfers was
1: memory the more the better for ZFS ( 5GB+ )
2: cache drive
2: cache drive
I have 4GB in the system, but ~2GB are assigned to VMs, so unfortunately not a lot at this point. I'll do some quick testing with and without the VMs running to see how much of a difference it makes.
EON hasn't been ported to ARM architecure has it? There is an ARM port of OpenSolaris 11. :confused:
No EON has not been ported to ARM. Correct me if I'm wrong but I believe that port you refer to of Opensolaris is really old.
As far as I know Openindiana or Illumos has not been ported.
https://www.illumos.org/projects/illumos-gate/wiki/Project_Ideas
MIPS or ARM port gdamore / DeanoC very hard C, MIPS or ARM, low-level system level architecture Port illumos to a MIPS platform such as Octeon (64-bit) or Alchemy (32-bit) or to an ARM platform like Nvidia Tegra (32 bit).
