Having trouble getting VPN work using CyberGhost
yarr
I really thought I was doing it right but i'm afraid I might need help and the few things I have found so far on the forum didn't work unfortunately :( (attaching log in case it's helpful)
  • log.txt
I use CyberGhost with default settings (just disabled compression and DNS because I use PiHole) and never had a problem with Asus and Merlin
Yeah, I get that it should have worked. It didn't so I posted my log hoping someone with more understanding might lend a hand. Maybe I should try disabling those two things? I'll try it out as soon as I get the chance. TY
The error refers to a missing username, did you fill this in?
Please provide screenshots of your VPN Client configuration.
