thanks, i had referred to this thread about setting the client with 2 different gateway within the same subnet. and i had successfully done it to assign certain client to second gateway.
but is there an option to setup/assign 2 gateway to client with different gateway metrics?
my main router/gateway is 192.168.1.1 running Asuswrt
my second router/gateway is 192.168.1.9 running Openwrt
my intention is to set the dhcp-host to have second gateway to isp1 but with lower metrics, so that the host will fall down to isp1 if isp2 is fail or not working, is this possible?
i would like all client to use isp2 as much as possible and only switch to isp1 in case isp2 is down.
looking forward for any suggestion.
Custom Gateway
First of all, I hope everyone is Safe and Healthy during those days, Secondly i been a big fan of this forum and you guys had helped me a lot of the years with information that is posted here. Today i got into a situation that i'm trying to solve that i haven't found an answer for so i...
www.snbforums.com
dhcp-option=tag:isp1,option:router,192.168.1.1
dhcp-option=tag:isp2,option:router,192.168.1.9
dhcp-host=xxxx:5B:8B:30,set:isp2,192.168.1.40
dhcp-host=xxxx:A7:ED:2D,set:isp2,192.168.1.41
dhcp-host=xxxx:11:41:9C,set:isp2,192.168.1.42
dhcp-host=xxxx:C2:36:FB,set:isp2,192.168.1.43
dhcp-host=xxxx:45:4F:B7,set:isp2,192.168.1.44
