[Help] asuswrt-merlin in netgear 6300
jchuang1977
Hi All,
I flash the asuswrt-merlin AC68U to netgear6300v2 ( 4708 + 4360 + 4331 ) with my own build image. It works but only 2.4G , I can not find the 2.4G SSID.
I found ASUS-AC66U's wifi chip combination is the same as 6300v2.
How to modify the compile config flag to fit the 6300v2 ?
Thanks for the help. :D
try open source forums, i doubt Merlins going to help anyone with a netgear, the guys got enough on.
Just a side note. dd-wrt is available for that router.
