Help choosing cable router
Paul Ryan
hi, i need help picking a new router, i currently use the superhub 2ac but want something that will improve the wireless range and speed throughout the house, here's a list of activities for the router
1. web browsing
2. online gaming
3. newsgroups and torrents
4. wireless printing
5. streaming (netflix, amazon, kodi, live football)
there will be anything upto 20 wireless devices and 3 wired devices connected at once
here are the devices i'm considering
1. NETGEAR R7500
2. ASUS RT-AC88U
oh and one last thing i must be able to turn off all the lights on it
You're not going to get much better than what you have at the moment - so focus, if possible, putting the Superhub 2AC in an ideal location to cover most of your devices...
If you're in a smallish flat, you've got more than enough already...
i live in a terraced house, all upstairs is fine but some rooms downstairs the signal strength does
might consider picking up an N600 class (or AC1200 class) AP to light up the rooms downstairs perhaps connected via ethernet
sh2ac is upstairs and can't be relocated downstairs so can't use ethernet downstairs as its too far, with the current setup i can get either range or speed but not both together which i thought i would with a dedicated router
as long as it uses the 2nd gen MU-MIMO if it is one, otherwise it will do fine. What makes tp-link cheaper is that they use lower to midrange chipsets (i.e. 800mhz instead of 1.2Ghz broadcom) and that they only have basic features. So it really depends on what you need. ASUS has a lot of features in their firmware. As long as it is not quantenna it will be fine.
In terms of wifi only slight differences if they use the same chip so it goes down to antennas and design.
