help, code for disable runner and flow cache in ssh putty please
berku4
Hi, I've been following the forum for a long time and I have great respect for all members. first apologize for the language, I'm not English. and second, I wanted to ask for a little help. I need a code to run in putty, a code that deactivates runner and flow cache at every reboot so I don't do it manually every time. I'm crazy and I can't do it, please if someone can send me a code to run it, thanks.
i tried:
#!/bin/sh fc disable /jffs/scripts/services-start
#!/bin/sh runner disable /jffs/scripts/services-start
thank
Which router model do you own? You can run this once and it should stay disabled.
runner disable
fc disable
fc flush
nvram set runner_disable="1"
nvram set fc_disable="1"
nvram set runner_disable_force="1"
nvram set fc_disable_force="1"
nvram commit
