Hi all,
I'm new here and I was wondering if I could get some advice and guidance in this thread.
I don't have much experience with routers as I only use the ISP router that is provided from my network. I bought a ASUS RT-AX58U black friday deal and I have a few questions. Hope someone can answer them and guide me.
- Will the router I bought support VPN?
- If it does, is there a guide to set up the VPN on the router as I don't have a clue how to do it?
- Also once the router VPN is setup, is there a option to select specific device that is connected to the router to enable the VPN and disable it easily? Reason behind is if I play games I want it disabled.
The router will arrive on the 2nd Dec. so as of the moment I can't try it. I'm just gathering info for now to decide if I will get the NordVPN black friday deal.
Thanks in advanced.
P.S. English in not my first language.
Edited:
Found this guide - https://www.wirelesshack.org/how-to-setup-a-asus-rt-ax58u-ax3000-as-a-vpn-router-using-merlin.html
Now my main question would be is there a settings on this router to toggle on and off the VPN on a specific device in case I will be playing games. Thanks.
Thanks in advanced.
Edited:
