Help me Dump ! and Flash CFE
BreakingDad
Trying to do this from another forum to change the regions to #a
Dump command:
dd if=/dev/mtd0 of=/tmp/original_cfe1.bin
Flash command:
mtd-write -i new_cfe.bin -d pmon
(obviously change the paths/filenames to suit).
Can someone give me the exact lines with paths/filenames for a blank usb stick plugged into asus rt-n66u.
I understand how to hex edit the country/region codes to #a but not sure of how to dump and reflash from the memory stick and it's important I get it right hence the questions.
Apparently "All other tools are already built into the N66U (as it runs a MIPS chip)."
1000 thank u's
