Help me, Xbox Disconnects When Transfering Files
BreakingDad
I have an RT-N66U, latest merlin build.
I have an issue whereby if I am transfering a file to my Nas Drives via the network (From XP to seagate central (ethernet to router) and WDMy Passport usb to router) Over 2.4ghz connection. It somehow interferes with the xbox 360 in another room and causes my son to disconnect from xbox live.
I have a 100/6 mb cable line. I've tried port forwarding all the ports for the game, the console is also in DMZ and I've also tried adding the xbox live stuff to traffic management. I've tried with traffic management off and on automatic as well. The only fix seems to be if I stop transfering a file. The strange thing is that uTorrent works fine and doesn't disconnect the xbox at all. No problems streaming stuff off the hard drives either. Just when sending a file to the harddrives. Could it be 2.4ghz interference on transmitting? rather than overloading the network ? I don't know, I'm stumped. I am using an N66U transmitter on my pc so could this be blotting out the xbox weedy one in the next room ? I had a similar problem to this while transfering files over the 5ghz band, it interfered with the wii pad, I fixed this by using the pc on 2.4ghz band.
Any help from you clever people would be great. Thanks for reading- BD
This is going to sound like a stupid question, but I ask because I just recently had to re-enable it myself after realizing some other change had removed it:
Do you have "Optimized for Xbox" checked under your wireless config options?
Yes Optimised is ticked :)
As I say its only when I transfer a large file down to the nas from the pc. Bit of a pain but I'll have to do the transfers over night when the xbox isn't in use until I find a better solution.
Thanks anyway.
Just to rule the possibility out, try replacing the Ethernet cable between the NAS and the router.
Pretty sure its not the cable, its a brand new cat 6.
I did a netstat last night on the pc.
Would QOSing port 139 help? or would that screw other stuff
