Help Needed: Assign LAN port as WAN
BradsterACT
Is it possible to assign a lan port as the wan interface via shh?
I cant use gui as its an AI mesh node and wan port doesnt work.
What are you trying to do? Setting up an ethernet backhaul?
You only need the WAN connected on the router, not the nodes.
What makes you think the WAN port is broken? If you reset it and use it in other modes, does it not work? It’s probably a configuration issue rather than hardware issue.
get out the inserted thing, maybe you have to straighten and bend the pins to be parallel up again. Should be possible.
Dont think it is electrically demaged by a 3 years old.
  • Like
Reactions: kfp
