New to this forum and hoping you can all help with my issue.
Currently moved into a new house and rather not run cables to the main level but finding a problem already. Currently have a cable modem located on the lower level and connected ehternet into a Netgear WGR614v7.
I have an xbox360 with the microsoft wireless adaptor which is barely seeing a signal from the current wireless router. Also I have a dish 722 with ethernet receiver that though doesn't need to be setup, would be nice to have the option.
I currently am running a Netgear Wgr614v7 but have a Linksys WRT54g version 5 available. Now can I take one of these routers, connect the Xbox 360 and Dish 722 wired into it and then send the signal to the other router that is hooked into my cable modem? If this is possible any advice how to setup and what would be the best configuration?
