[HELP] Performance issue TS-110
boris86
I purchased the TS-110 after reading the review on the site. I concluded it is the best NAS in my budget.
As the review and on Qnap website written that write speed is appx. 40MB/s
I get only 25 MB/s.
I have dell e6400 Q8600/2GB Intel 1GB LAN 82567LM Win7.
Qnap firmware is 3.4
Any advise?
Thanks for anyone who helps.
The 40 / 44 MB/s performance is for transfer of > 1 GB files, i.e. large sequential read/write. For folders of smaller files, performance will be lower.
LAN cofig:
Link speed: 1GB Full duplex
Gigabit master slave mode: auto
interrupt moderation: enabled
jumbo packet: disabled
large send offload v2 (ipv4): enabled
large send offload v2 (ipv6): enabled
locally administered address: blank
log link state evant: enabled
priority & vlan : priority & vlan enabled
receive side scaling: enabled
wait for link: auto
performace options-
adaptive inter-frame spacing: disabled
flow control: rx-tx enabled
interrupt moderation rate: adaptive
revieve buffers: 256
transmit buffers: 512
tcp/ip offloading options-
ipv4 checksun offload : checked
tcp checksun offload (ipv4): checked
tcp checksun offload (ipv6): checked
udp checksun offload (ipv4): checked
udp checksun offload (ipv6): checked
NAS LAN config:
1G full duplex
write speed from pc to nas is 25 MB/s
read speed from nas to pc is 40 MB/s
moving files speed inside the nas is 15 MB/s
file size is 1.4GB
thanks again for helping :)
Had the same unit for a while and found speeds were pretty variable, with large file CIFS writes around 25-30MB/s being the most common. This was with all other QNAP services disabled, firmware 3.4, formatted with ext4 I think...
I never saw anywhere near 44MB/s in the year I owned it though.
