Ok I now have the server and client started but still showing my ISP IP when I got to whatismyip.com
E:Option ==> diag
WireGuard VPN Peer Status
interface: wg21
public key: rD...
private key: (hidden)
listening port: 51820
interface: wg11
public key: SM....
peer: R.
endpoint: 192.252.213.114:1443
allowed ips: 0.0.0.0/0
persistent keepalive: every 25 seconds
WireGuard VPN Peers
Peers (Auto=P - Policy, Auto=X - External i.e. Cell/Mobile)
Server Auto Subnet Port Annotate
wg21 Y 10.50.1.1/24 51820 # RT-AX88U Server #1
Client Auto IP Endpoint DNS MTU Annotate
wg11 N 10.13.53.185/24 192.252.213.114:1443 9.9.9.9.9 1412 # TorGuard WireGuard Config
DEBUG: Routing info MTU etc.
33: wg21: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
link/none
inet 10.50.1.1/24 scope global wg21
valid_lft forever preferred_lft forever
35: wg11: <POINTOPOINT,NOARP> mtu 1420 qdisc noop state DOWN group default qlen 1000
link/none
inet 10.13.53.185/24 scope global wg11
DEBUG: Routing Table main
10.50.1.0/24 dev wg21 proto kernel scope link src 10.50.1.1
DEBUG: RPDB rules
0: from all lookup local
9810: from all fwmark 0xd2 lookup 210
10010: from 192.168.5.103 lookup main
10011: from 192.168.5.109 lookup main
10012: from 192.168.56.0/24 lookup main
10210: from 192.168.24.0/24 lookup ovpnc1
10211: from 192.168.224.0/24 lookup ovpnc1
10212: from 192.168.50.0/24 lookup ovpnc1
10213: from 192.168.55.0/24 lookup ovpnc1
10214: from 192.168.5.0/24 lookup ovpnc1
10215: from 192.168.24.0/24 lookup ovpnc1
10216: from 192.168.224.0/24 lookup ovpnc1
10217: from 192.168.50.0/24 lookup ovpnc1
10218: from 192.168.55.0/24 lookup ovpnc1
32766: from all lookup main
32767: from all lookup default
DEBUG: Routing Table 121 (wg11) # TorGuard WireGuard Config
192.168.5.0/24 dev br0 proto kernel scope link src 192.168.5.1
DEBUG: Netstat
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
10.50.1.0 0.0.0.0 255.255.255.0 U 0 0 0 wg21
DEBUG: UDP sockets.
udp 0 0 0.0.0.0:51820 0.0.0.0:* -
udp 0 0 :::51820 :::* -
DEBUG: Firewall rules
DEBUG: -t filter
Chain FORWARD (policy DROP 0 packets, 0 bytes)
num pkts bytes target prot opt in out source destination
1 0 0 ACCEPT all -- * wg21 0.0.0.0/0 0.0.0.0/0 /* WireGuard 'server' */
2 0 0 ACCEPT all -- wg21 * 0.0.0.0/0 0.0.0.0/0 /* WireGuard 'server' */
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
1 0 0 ACCEPT all -- wg21 * 0.0.0.0/0 0.0.0.0/0 /* WireGuard 'server' */
2 0 0 ACCEPT udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:51820 /* WireGuard 'server' */
Chain OUTPUT (policy ACCEPT 88940 packets, 25M bytes)
DEBUG: -t nat
Chain PREROUTING (policy ACCEPT 5432 packets, 951K bytes)
1 334 23749 WGDNS1 udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:53 /* WireGuard 'client1 DNS' */
2 0 0 WGDNS1 tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:53 /* WireGuard 'client1 DNS' */
3 0 0 ACCEPT udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:51820 /* WireGuard 'server' */
Chain POSTROUTING (policy ACCEPT 1204 packets, 91965 bytes)
1 0 0 MASQUERADE all -- * wg11 192.168.5.0/24 0.0.0.0/0 /* WireGuard 'client' */
Chain WGDNS1 (2 references)
1 90 6134 DNAT all -- * * 192.168.5.0/24 0.0.0.0/0 /* WireGuard 'client1 DNS' */ to:1.1.1.1
DEBUG: -t mangle
Chain FORWARD (policy ACCEPT 8169 packets, 1132K bytes)
1 0 0 MARK all -- * wg11 0.0.0.0/0 0.0.0.0/0 /* WireGuard 'client' */ MARK xset 0x1/0x7
2 0 0 TCPMSS tcp -- wg11 * 0.0.0.0/0 0.0.0.0/0 tcpflags: 0x06/0x02 /* WireGuard 'client' */ TCPMSS clamp to PMTU
3 0 0 TCPMSS tcp -- * wg11 0.0.0.0/0 0.0.0.0/0 tcpflags: 0x06/0x02 /* WireGuard 'client' */ TCPMSS clamp to PMTU
4 0 0 MARK all -- * wg21 0.0.0.0/0 0.0.0.0/0 /* WireGuard 'server' */ MARK xset 0x1/0x7
5 0 0 TCPMSS tcp -- wg21 * 0.0.0.0/0 0.0.0.0/0 tcpflags: 0x06/0x02 /* WireGuard 'server' */ TCPMSS clamp to PMTU
6 0 0 TCPMSS tcp -- * wg21 0.0.0.0/0 0.0.0.0/0 tcpflags: 0x06/0x02 /* WireGuard 'server' */ TCPMSS clamp to PMTU
Chain PREROUTING (policy ACCEPT 22812 packets, 3591K bytes)
1 0 0 MARK all -- wg11 * 0.0.0.0/0 0.0.0.0/0 /* WireGuard 'client' */ MARK xset 0x1/0x7
2 0 0 MARK all -- wg21 * 0.0.0.0/0 0.0.0.0/0 /* WireGuard 'server' */ MARK xset 0x1/0x7
Use command 'diag sql [ table_name ]' to see the SQL data (might be many lines!)
Valid SQL Database tables: clients fwmark passthru servers traffic
devices ipset policy session
e.g. diag sql traffic will show the traffic stats SQL table
WireGuard ACTIVE Peer Status: Clients 1, Servers 1
