Help setting up aimesh
ludespeedny
I am trying to set up an aimesh router and running into issues. There must be something obvious I'm missing, but not sure.
Equipment:
Main Router: AC3100 fairly fresh (last month) 386_9 install
Secondary Router: AC68U w/ fresh reset 386_9
I have tried to use the add node option from the main router, but it never sees the secondary router. I have also tried official ASUS firmware on the secondary as well as hardwiring from the lan port from the main to wan port on secondary, but never shows up. Any ideas?
The secondary works fine on it's own as a router and all ports/wifi are good.
Was the second device configured for the operation mode as an AiMesh node?
I initially tried setting it up like that, but it never found it. What I typically tried was a reset using the WPS method and when it rebooted, didn't do anything on it and tried to find it on the main. I didn't see aimesh node as an option after a reset.
Did you try second device with stock firmware?
wired backhaul?
I recently took some AC5300's I had and repurposed them for my wife's cousin. One as a router, and the other as a node. I could not add the second 5300 nor could it be found to add it as a node.
My goal was to add using wireless, then move to a wired back haul. Both were on Merlin 386.3 and I upgraded both to Merlin 386.10 beta before deploying (need to run a couple scripts on the node, hence using Merlin, not stock, on it. During the upgrade, I did something to the config for that node 5300 that prevented being able to add it. But I did eventually add it, over a wired backhaul.
What worked for me, before adding the mesh node I set the router to prefer Ethernet backhaul, first. Then connected WAN on node 5300 to a LAN port on router 5300 (note: still wouldn't find/add it). Then I WPS reset the node 5300 while connected, and within seconds after after rhe reboot and the WAN became active on that node 5300 (based on the 5300 WAN inticator LED coming on) I went back to add an AIMesh node. Immediately was discovered and I was able to add the second 5300 as a node. One the router 5300 WPS was enabled not sure if that really matters anyway, the node was fresh off a WPS reset, hadn't even logged into it.
The only thing I can come up with is that logging into the node after the initial WPS reset under 386.3 to upgrade the firmware the first time set/changed something that messed with the discovery process, even setting it's operational mode to AiMesh node didn't help. I had to set the preference for Ethernet backhaul on the router, then get the physical connectivity done, then both router and node powered up. After which a WPS reset on the node (clearing out ID/password on the node is what, I suspect, allowed the device discovery to occur) to start it up clean/default as it came back up, only then was it discovered allowing me to add it.
Then after both were up, while configuring the 2.4Ghz wireless to turn off 802.11b on the router, I then had to SSH into the node to set nvram to the same seting (to set in nvram to disable 802.11b is wl0_rateset=ofdm) on the node, commit it and reboot. Otherwise while the router has 802.11b disabled, the node(s) has it enabled slowing things down on the 2.4Ghz WiFi. That setting isn't propagating from the router, an AiMesh/Wireless closed source issue not Merlin specific.
Unfortunately I have not been able to go back to repeat the process and test adding a node in a measured/controlled/repeatable way, sorry...
(Teen age daughter on her iPhone/iPad home on Spring Break, on the devices all day & night, online :rolleyes:)
Good Luck...
Threads like this will be coming as long as Asuswrt-Merlin firmware claims full AiMesh support. This is the third thread in one week.
Thanks for all the help. I finally decided to wipe both and re-install merlin on them via recovery. I just got them back up and got the error about "not close enough, or someone else is trying to set them up". I was doing it wirelessly, so I'll try wired tomorrow. At least some progress though.
