I am a self taught complete network novice. So forgive me if this is a stupid set up! All advice gratefully received.
I am in UK and use 4G LTE for internet. I have a TP-Link TL-MR6400 with sim card. Ethernet cable from LAN output to an Orbi RBR50 Internet port input. This then has 3 satellites. Running Voxel firmware. TP Link is 10.0.0.1 and Orbi is 192.168.1.1 with 255.255.255.0 subnet. I also have a TPLink Archer C50 set as a wireless extender for the Orbi wireless network too. Usually 30-35 devices attached to the Orbi network (mix of wired & wireless).
All works well, EXCEPT that periodically (once every day or couple of days) the Orbi loses internet access partially.
By that I mean I can Ping out OK. A weather station that feeds Wunderground continues OK. An ADSB receiver feeding data remains connected. But I cannot browse the internet either using IP address or http(s) and IOT devices lose connection.
I've spent ages trying to figure out what is going wrong and what I need to do to prevent it happening. But to no avail.
I simply don't have the necessary knowledge - and despite google, I cant turn up anything similar for advice.
So I post here in desperation!
I have the Orbi set as the TPLink DMZ Host IP and I've tried both fixed IP for the Orbi and using TPLink DHCP to issue a reserved address to Orbi. Neither makes any difference.
To restore a working connection I dont need to reboot anything (although rebooting either the Orbi or TPLink will restore things) I simply go to the Orbi Internet Setup page, change nothing but just click "Apply". I dont know what that actually does, but connection is usually restored.
So anyone any ideas as to what is going on and/or suggestions to improve th setup?
David
David
