macster2075
Hi..
I am trying to eliminate double NAT.
The way I have my RT-AC68P router is as follows.
ISP Modem LAN port to WAN port on Asus Router.
I have the option to bridge the ISP modem (Actiontec T3200) (192.168.254.254), but, I can't do that because this modem is located in my office which provides internet to my work computer via Ethernet. (it needs to be Ethernet connection) - If I bridge it, then only ONE Lan port would be available on the modem and will not be able to provide Internet via Ethernet to the Asus router.
The Asus (192.168.1.1) router is on another part of the house providing Wireless and Wired connection to the rest of the devices on my network. (ran Ethernet cable through attic).
As you can see, both the modem and router are under different networks.
I know that I can just connect the Asus router from LAN to LAN on the modem and change its IP to be on the same network as the modem....but, if I do so, will I still be able to have the Asus router provide Wireless and Wired Internet?
And... I have some settings on the Asus router like jffs and such... will that still be enforced?
And finally... this means that the ISP modem will be doing all the DHCP.... is that a good thing?.. I ask because I don't know if its CPU is as fast as Asus.
Any thoughts?
Any thoughts?
