I'm setting up a MoCA 2.5 network at my house for the first time and have a few questions I'm hoping the experts here can help my with before I start.
First off, my house seems like it is wired perfectly for MoCA. I have six separate runs of RG6 coax, all of which terminate in my garage where the one outside cable line comes in. Right now, the outside line is directly connected to my cable modem and all of the other coax is dark.
So far I've ordered three Actiontec ECB6250 MoCA 2.5 Network Adapters, a Holland MoCA POE filter and a Holland MoCA Rated 3-Way Balanced Splitter to make my MoCA network, all of which should arrive next week. I already have a TP-Link TC7650 modem, a pair of eero Pro 6s and a couple of Netgear GS305 unmanaged gigabit switches to complete the setup.
I've read through some other similar threads on here and think that I have a pretty good idea of what my setup should look like, but I have three questions that remain:
- Is it OK if I put a switch between my main router and the MoCA adapter?
- My internet installer put a 6 dB attenuator in front of my modem as I guess the signal levels were too high. Can I remove this once I'm using the splitter as it has a -5.5 dB loss on all three connections?
- I made a quick diagram of my planned setup. Any issues with this config?
