I really want to use the Merlin Firmware (especially for hosting OpenVPN) but it seems to be causing ping/latency issues.
I've tried several to stay on Merlin a few times in the past couple months, but I always run into the same issue. My ping/latency jumps dramatically when I'm on Merlin. Or my connection is unstable. It's very apparent when I'm gaming online. My ping is very unmanageable (usually over 1000ms). It moves a lot but is often so high I can't bear to play.
I then flash it back to Asus firmware and the ping/latency is much more stable and lower to where I can play normally.
I've tried reflashing multiple times each time either modifying something or not modifying anything at all to try and get it stable.
I do not have QoS on. I've tried with OpenVPN off. Pretty much flashed, set some static IPs in the DHCP and that's it.
Anything I can try to figure out what's causing this? I am completely stumped after digging around through all the settings and trying all different combos.
