Help with URL Filter
daramullally
Hi
I am trying to setup URL Filtering in the Firewall tab (to block Amazon Fire TV firmware updates). I have enabled URL Filter and add the following in the URL filter list:
amzdigitaldownloads (to block http://amzdigitaldownloads.edgesuite.net)
softwareupdates (to block https://www.amazon.com/?tag=snbforums-20)
boards (just testing blocking - www.boards.ie)
But when I go to www.boards.ie as an example it loads the page. I have tried resetting to factory settings and setting up again but still it doesn't seem to block anything.
I am using Merlin build 376.47 on Asus N66U. As a workaround would using dnsmasq work as mentioned in this thread: http://forums.smallnetbuilder.com/showthread.php?t=12736&highlight=URL+filter
Any help would be greatly appreciated. Please note that I am a relative newbie on here.
Hi
I posted a script that I used to test creation of manual URL/KEYWORD filters
http://forums.smallnetbuilder.com/showpost.php?p=146582&postcount=6http://
So invoke the script
   ./URLString_match www.boards.ie -url
then open www.boards.ie and then issue:
   ./URLString_match ?
and you should see that there is one packet matched against the filter:
admin@RT-AC56U:/jffs/scripts# ./URLString_Match.sh ?
(URLString_Match.sh) 17758 Martineau URL and Keyword matching.... [?]
Chain FORWARD (policy DROP 0 packets, 0 bytes)
num   pkts bytes target     prot opt in     out     source               destination
1        1   335            all  --  *      *       0.0.0.0/0            0.0.0.0/0           WEBSTR match url www.boards.ie
2    1483K 1574M ipttolan   all  --  *      br0     0.0.0.0/0            0.0.0.0/0
so replace the tracking rule with a reject rule
   ./URLString_match www.boards.ie -d
./URString_match www.boards.ie reject -url
and now try to access www.boards.ie
hopefully you will be rejected! and can confirm the matching reject rule
   ./URLString_match  ?
(URLString_Match.sh) 17861 Martineau URL and Keyword matching.... [?]
1        1   454 REJECT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           WEBSTR match url www.boards.ie  reject-with tcp-reset
I set all my filters manually, although in the GUI I have enabled all three filters but have no entries in any of the tables.
I'm not sure if the GUI setting enables the correct loading of the kernel iptables filter modules - probably not?
If the manaul rules work, then you can add the same URL filter rule via the GUI, and be able to compare the rules - to ensure that they are identical.
Regards,
Hi
Thanks for your help with this. I have tried the above but I can still access www.boards.ie.
Here is the output from ./URLString_match ?
admin@RT-N66U-A5A8:/jffs/scripts# ./urlstring_match ?
(urlstring_match) 1313 Martineau URL and Keyword matching.... [?]
Checking filter request ARGs
Flushing existing filter(s) for URL/Keyword ?
Inserting filter(s) for URL/Keyword ? for using
1        0     0 REJECT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           WEBSTR match url www.boards.ie reject-with tcp-reset
2        0     0 REJECT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp spt:80 TIME on all days STRING match "boards" ALGO name bm TO 65535 reject-with tcp-reset
3        0     0 PControls  all  --  br0    *       0.0.0.0/0            0.0.0.0/0           TIME from 12:0 to 14:0 on Sat MAC AC:22:0B:69:32:32
4        5   280 PControls  all  --  br0    *       0.0.0.0/0            0.0.0.0/0           TIME from 18:0 to 21:0 on Sat MAC AC:22:0B:69:32:32
5        0     0 DROP       all  --  br0    *       0.0.0.0/0            0.0.0.0/0           MAC AC:22:0B:69:32:32
6        0     0 PControls  all  --  br0    *       0.0.0.0/0            0.0.0.0/0           TIME from 12:0 to 14:0 on Sat MAC 28:37:37:C9:DA:FD
7        0     0 PControls  all  --  br0    *       0.0.0.0/0            0.0.0.0/0           TIME from 18:0 to 20:0 on Sat MAC 28:37:37:C9:DA:FD
8        0     0 DROP       all  --  br0    *       0.0.0.0/0            0.0.0.0/0           MAC 28:37:37:C9:DA:FD
9     2185  119K ACCEPT     all  --  *      *       0.0.0.0/0            0.0.0.0/0           state RELATED,ESTABLISHED
10       0     0 logdrop    all  --  !br0   eth0    0.0.0.0/0            0.0.0.0/0
11       0     0 logdrop    all  --  *      *       0.0.0.0/0            0.0.0.0/0           state INVALID
12       0     0 ACCEPT     all  --  br0    br0     0.0.0.0/0            0.0.0.0/0
13       0     0 DROP       icmp --  eth0   *       0.0.0.0/0            0.0.0.0/0
14       1    84 ACCEPT     all  --  *      *       0.0.0.0/0            0.0.0.0/0           ctstate DNAT
15     652 44120 ACCEPT     all  --  br0    *       0.0.0.0/0            0.0.0.0/0
My output seems a lot longer than your example.
Dara
Try disabling NAT acceleration. 376.47 has a bug where the traffic doesn't get properly marked, so it doesn't bypass CTF as it should.
Hi
Dara
I deliberately truncated the iptables rule list output in my post for the sake of brevity (no point showing lengthy iptables rules that are irrelevant!)
I originally wrote the script to overcome the limitations of the GUI, and my script quickly allows tracking rules to be instantly applied without the overhead where the GUI apparently restarts services.
If you add the following tracking rules, does it show any hits either URL or STRING?
 ./urlstring_match . -str
 ./urlstring_match . -url
as clearly most URLs contains the '.' character (even if someone sneakily tried to avoid the URL filter by specifying the actual IP address!)
As I said, I recall that way back I was not happy with the GUI, so I don't think the iptables modules are not made availble by the kernel if you haven't explicitly enabled all 3 filter options but I always do this and reboot.
All I can suggest is that you too also enable all three filters and reboot
iptables  -m webstr  -help
EDIT: Just seen this post regarding Parental control:
http://forums.smallnetbuilder.com/showpost.php?p=147952&postcount=25
and this may unfortunately also impact the URL/KEYWORD filtering?..although I suspect this would only be true for GUI applied filters, since my script adds the tracking rules before the jump to the PC iptable chain table.
It seems to be working now after disabling parental controls and rebooting. I already had enabled the 3 filters. Many thanks Martineau and RMerlin.
I have noticed that web browsing seems a bit slower now. I will investigate further in the morning.
Dara
