Help with Wireguard Client set up, access local LAN & provider DNS
Khadanja
Trying to set up WireGuard using SurfShark config file. If I have default AllowedIPs = 0.0.0.0/0 as provided in the config file, everything works but I can't access local LAN. What do I need to put their to be able to access local LAN devices while connected to VPN & VPN Provider DNS servers should be used. Have tried a few setting which enable me to access LAN devices but SurfShark VPN servers in config file get ignored & AdGuardHome provided DNS gets used which is installed on router.
[Interface]
PrivateKey =
Address = 10.14.0.2/16
DNS = 162.252.172.57, 149.154.159.92
[Peer]
PublicKey =
Endpoint = us-lax.prod.surfshark.com:51820
