Hello,
Not sure if this is a bug or just the way it's been engineered...but if you have a guest network that has it's SSID configured as hidden and you do not sync to AI Mesh node the SSID will be hidden. If you then sync it to your AI mesh nodes..the SSID is no longer hidden.....
Just wondering if this is a bug that can be fixed? Thanks!
AiMesh router | |
RT-AC3100 | Current Version : 386.3 Merlin |
AiMesh Node | |
RT-AX92U | Current Version : 3.0.0.4.386_44985-gd27c0a3 Asus |
