Royal2000H
Sometimes I get a relatively high rate of dropped packets. For example, I'll play a game, latency is relatively low (under 100, even under 50), then I suddenly lag, keep playing, lag, keep playing, lag and get disconnected.
I always though this was an issue with Time Warner Cable. Until I decided to ping 192.168.1.1 with 100 packets while playing. When I lag out, I switch windows and notice that my pings aren't reaching the router either. When I'm disconnected from the gaming server, something like 3 or more consecutive pings to the router aren't returning.
Even when not gaming, just browsing the web, I can get this stuttering internet. Normal pings are <1ms-3ms. Even at this very moment I got 6% lost, min = 0 ms, max = 66 ms, average = 1 ms. A few minutes earlier: 9% lost, min = 0 ms, max = 1034 ms, average = 25 ms.
Connected to RT-AC68R with a PCE-AC68 on the 5GHz band. Windows 8.1 shows 5 full bars the whole time.
I think this is often temporarily remedied by rebooting the router. Any fix though? Nothing interesting showing up in the General Log.
TL;DR: Wireless signal strong, periodic phases of sporadic dropped packets. Usually improved by rebooting router. Any fix?
