Hi Mr RMerlin.
A BIG thanks for your effort and work on the AC68U
I am running your fw xxxxx.38_1 and have the Huawei 3276 150mb/s modems as my Indoor from the internet and its my only way at the moment.
The Router runs inccredible good but my speed is only about 25mb/s because the lack of (as I been told) the driver "cdc_ncm.c" so the modem can work att higher speeds. I am not a programmer or anything like that så I cant fix it my self
So my Q to You Mr RMerlin:
Is there any chances that You sir will put in that driver in your firmware builds ? so its possible to gain the higher USB modems speeds?
If not I understand but I just have to ask the question
Best Regards
Jonny Andersson
Sweden
Best Regards
Jonny Andersson
Sweden
