My new apartment is undergoing renovation right now. I need recommendations for how I should create a LAN, which consists of a wired gigabit Ethernet, as well as wireless N-class WiFi.
I'm looking to build a wired LAN to all rooms with CAT6 cabling and wall sockets (1 to 6 per room). This will mean a total of 20-24 wall sockets. I have 2-3 PCs, several VoIP phones, a network printer, some home entertainment devices and a NAS using the wired LAN. Also I need a secured WLAN for limited access by my own wireless clients (2-3 computers, later on maybe also CCTV) and a guest SSID that I can enable whenever it's needed for my guests.
My WAN connection is either ADSL or a cable modem, which will be hooked to a LAN switch in my tech closet. In there I will also place a NAS with RAID 1 or 5. As for WiFi, I was thinking of using at least one AP, maybe even two.
So what do I need help with?
- Which device should do the NAT and allocate local IPs with DHCP? A good LAN router or maybe just a prosumer grade wireless router?
- Is there any big differencies between wired LAN switches? If so, can you recommend me a gigabit switch with good peformance? Remember that I will have 2-3 concurrent wired clients with a high traffic volume. Also some occasional HD streaming on the top of that from my NAS to the DLNA enabled Sony HDTV.
- Which NAS would be good for 4 HDDs in a RAID 1 or 5 configuration? My desktop PCs and wireless clients host their files on the NAS and only have one HDD per device for apps, essential files and the OS.
- My primary wireless client is a threeband capable ThinkPad X220 (exactly the same as Tim's testbench), which means I'm looking for a prosumer grade AP. Any recommendations for two WiFi APs with support for two SSIDs (both being broadcasted from both APs)? I don't need any fancy storage support etc. Just solid performance and good firmware updates. Both APs don't have to be the same model.
Especially at least one of the APs should have support for an external antenna, as the AP is inside the lowered ceiling and thus requires an external antenna that can be mounted below the ceiling. The other AP will be inside the tech closet.
- I'd prefer to have a IPv6 enabled network which would be future proof. I'm most likely going to have IPv6 with my WAN. Which devices would be good for IPv6 compatibility?
