BeachBum
I’m trying to plan out my network set up for my new home thats being built. Below is a diagram of what I have I’m mind, do you think this is a good setup or do I need to change things?
My goals:
Phase1
Phase 2
My goals:
Phase1
- Wired Network
- Wireless Network
- Guest Network
Phase 2
- Wired Network
- Wireless Network
- Guest Network
- Security Camera Network
- Add it on second NIC on pfSense box? (if I’m using it for the APs then can’t do that?)
- Add it off the main LAN switch?
- How do I make the NVR or Synology RAID server accessible from/to both networks, but not the IP cameras? Or should I not do that and keep the NVR also separate? If so, how do I manage/view footage?
