Greetings
I need some advice on network components for a home remodel.
I am planning for a home renovation and have identified 24 networks drops and 6 POE networks drops.
For the regular drops does anyone have a recomendation for a 24 port smart giga e router? Also I am planning on request cat 6e is there anything I should watchout for or specifiy from a installer?
For the PoE drops I am planning on installing 4 IP cameras and 2 APs looking for recommended equipment? (avg cost of cameras $150, APs $100)
What PoE rotuer would you recommend again smart say 8 port giga e?
What IP carmera PoE would you recommend assume pan tilt zoom and compatability with synology survalliance station for recording
What G/N PoE access point would you recommend assume on avarage a max of 5 users per AP
I am also planning on adding home automation so if you have any recoomendations for that equipment I would like to hear it. Assume the following:
- Security System
- Lighting Control
- Logic engine if this then that
- Power monitoring circuit by circuit
- Thermostat contrlo- Lighting Control
- Thermostat control
- Security System
- Lighting Control
