Hi All,
I have been using smallnetbuilder for a long long time. I am gifted when it comes to Cisco and Cisco Wireless. I design them for a living, but I am a bit outside my comfort zone when it comes to home products.
Currently I own 3 Negear gs108t-100NAS switches with a Netgear FVS336G SSL VPN router and Dlink 825 wireless router.
I have tried for days to get this lan to work. The 3 biggest things it needs to do are:
1) Stream HI-def movies to any one of my big screen Tv's. I have Intel Dual NIC's that are teamed on every HTPC I have, and the Movie Storage server.
2) I own a CCIE lab, and use it from other places, and let friends use it.
3) I have Uverse, and I run it through my Switches.
ISSUES: the Netgear switches I own now, constantly drop traffic. That is fine for the internet, I am fine with Best effort prioritizing. The TV's constantly lock up. I have tried every combo of 100/Full, 1000/full, auto/auto, DSCP, flow control, nothing has solved the TV's from freezing.
I have heard there is an issue with the latest firmware on the gs108T-100NAS switches and when VLAN's are added it causes them issues.
Ok - What I need is to upgrade the switches. The SSL VPN firewall rocks, just fantastic piece of equipment. The DLINK-825 wireless router kicks butt too. I bought after reviewing it on here.
1) I want on 12-16 port main switch
2) 4x (5-8 port) switches.
3) All must be able to handle VLAN's, and trunking (802.1q)
4) Spanning-tree (802.1d, or 802.1w) are fine.
5) SFP based is not something I would consider at the moment. The SFP's are usually more expensive then the switch.
6) Gig would be nice, but in a home LAN, you do not see the benefits of that throughput.
I wish I could use my 3550's or 3560's but they are necessary in my CCIE lab.
Thank you in advance!
