BelarusOK
Hello peoples, really setup Homebridge to ASUS router?
I found this - Homebridge on LEDE/OpenWRT routers.
On Merlinwrt maybe posible?
I see Entware Packages, and found this:
1. olsrd-mod-mdns 0.9.7-v0.9.7 net MDNS/Zeroconf/Bonjour packet distribution
2. node-npm v8.16.0-2 lang NPM is the package manager for NodeJS
3. node v8.16.0-2 lang Node.js® is a JavaScript runtime built on Chrome's V8 JavaScript engine. Node.js uses an event-driven, non-blocking I/O model that makes it lightweight and efficient. Node.js' package ecosystem, npm, is the largest ecosystem of open source libraries in the world.
*. Need still openssl - do not know what to choose...
**. And to force all this to work...
Further...
> npm install -g homebridge
> homebridge
And we edit the file:
config.json
Need testers and help!
Further...
> homebridge
config.json
Quick Overview
- Node v4.3.2 or greater is required. Check by running: node --version. The plugins you use may require newer versions.
- On Linux only: Install the libavahi-compat-libdnssd-dev package: sudo apt-get install libavahi-compat-libdnssd-dev
- Install Homebridge using: npm install -g homebridge or sudo npm install -g --unsafe-perm homebridge (see below)
- Install the plugins using: npm install -g <plugin-name>
- Create the config.json file.
