MilwaukeeScott
I am purchasing a Smart [internet ready] HD 1080p TV. I plan to stream Netflix.
Right now I have one computer hooked up to my 10Mb cable modem connection. I doubt I will be using the computer while streaming Netflix.
My TV will be less than 4 ft from my cable modem.
I will be using a Cat6 6ft cable to hook up my internet ready TV to whatever router I buy.
I see lots of recommendations for a Dual Band N+ gigabit port router. Then I see posts that say streaming HD from Netflix is fine on a 10/100 standard router. The price difference is quite a bit between these two routers.
Is a standard $30 10/100 router fine or do I really need a Dual Band N+ gigabit port router?
