How build only cfe bootloader
vinimac
I would like build only the cfe bootloader. By typing 'make', inside asuswrt-merlin/release/src-rt-6.x/cfe I got:
mipsel-uclibc-cpp -P -DCFG_RUNFROMKSEG0=1 -DCFG_BOOTRAM=1 -DCFE_ROM_START=0xBFC00000 -DCFE_TEXT_START=0x80700000 -DCFE_DATA_START=0x81F00000 -DCFG_XIP=0 /home/vini/projs/mips/bcm5358u/tools/asuswrt-merlin/release/src-rt-6.x/cfe/cfe/arch/mips/common/src/cfe_ldscript.template ./cfe.lds
mipsel-uclibc-cpp: ./cfe.lds: No such file or directory
I found "./cfe.lds is dynamiclly generated", so how can I generate it?
Thanks.
I had the same problem but for RT-AC86U.
There do has a manual for build full firmware of router (*.w), but the CFE source code was not even compiled. And the CFE binary was copied from a prebuilt folder "sysdeps".
And i modified the CFE source code try to make some build error, but nothing happened in the whole compile(build) process.
Does anyone know how to build CFE firmware without building a full firmware ?
