How can I execute remote scripts using browser?
yelo3
Hello, I noticed that there is a folder named wwwext in which I can put .html files that can be accessed throught the http://xxx/ext/ path.
I also noticed that there is a cgi-bin directory, in which I think I can put some scripts that can be executed remotely in the router.
Is it correct?
In which language should I write the scripts?
You can't. For security reasons, the httpd daemon cannot be told to execute an arbitrary executable.
