Hello Guys ,
Is it possible to extract a Firmware from a router in one single .trx file ? by the way I'm using Windows OS .
If Yes, how can i do so ?
If No, why not ?
Thank You
You give us so little contextual info, it's impossible to answer. What particular router is this? Does it provide you with a shell access? Is that particular device using an encrypted partition? Does it provide you with an internal serial header?
There's no generic answer to your question, it depends on the particular router you are talking about.
What firmware are you trying to load?
The stock firmware for the WRT1900AC is an IMG file, not TRX.
1 - It's Linksys WRT1900.
2 - It does provide shell access.
3 - not that i know of
4 - don't knowbeyond my understanding
AFAIK the WRT1900AC does not provide any shell access. Also, its serial port is read-only, so you cannot use it to log inside the router and do a flash dump to a file.
You might be able to do a dump while in uboot, using the serial port (it only becomes read-only while in the firmware environment), however I don't know if uboot lets you dump the content of a partition to a file.
Otherwise, the only way to "extract" the firmware would be to see if a tool such as FMK is able to extract the contain of an upgrade file.
Hello Guys , Is it possible to extract a Firmware from a router in one single .trx file ? by the way I'm using Windows OS .
If No, why not ?
Welcome To SNBForums
