how come my transmission upload is limited to 40kb/s?
critical
currently using ac56u, anyway around it? my download master is set to upload n download is set to unlimited for bittorent, but no idea why in transmission it keep going back to upload at 40kb/s
thanks!
i noticed that too :((
i tryied all, changed speed, limits, start, restart, uninstall, changed ports, nothing worked.
ac56u :))
Optware's Transmission v2.82
It must be Optware's Transmission v2.82 that's the problem. I had the same issue with that software and got fed up with it! I compiled Transmissions v2.84 into Merlin's source code (RT-AC87U and RT-AC68U models only), and now I get download speeds of 5Mb/s and up speeds of 2Mb/s for a single torrent.
I only have two compiled versions for download:
To download the RT-AC68U firmware use:
https://truck.it/p/6G80zWGDb7
To download the RT-AC87U firmware use:
https://truck.it/p/x6tqenMUuj
The v2.84 transmission daemon is located at:
/usr/bin/transmission-daemon
Use at your own risk!
Transmission v2.84 Build Script Using Merlin's Source Code
Using Merlin's source code, you can build Transmission v2.84 using his documentation on Wiki. My Makefile script can be downloaded at:
https://truck.it/p/wKElwtr8lf
You just need to place this script into the router folder e.g. ~/asuswrt-merlin/release/src/router
and add the following to the Makefile:
ifneq (,$(wildcard Transmission.mak))
include Transmission.mak
endif
Sorry, I don't have the time to compile the code into Optware etc.
