Chase Quinnell
How do I enable NAT Loopback functionality on an Asus RT-N66u router? I am on the latest Merlin firmware 376.44
Hello RMerlin,
I am running 3.0.0.4.376.47_0 on RT-AC68U and looking for a option to disable NAT loopback feature, is there any ?
Thanks a lot,
Salvo
There's no option to enable or disable it. If for some reason you want to remove it, you will have to modify the iptables rule in the mangle table that implement it.
I see, thanks.
I am kind of novice, not very experience yet in Linux scripting and programming. Do you have any guide or at least could you give me more light on that like how to list the particular table that manage that or what to change ?
Appreciate your help,
Thanks,
Salvo
Why would you need to disable it anyway?
It's hard to provide any instructions because the code change depending on the firmware version you are running.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
