Thank you.here in 1st post you have info step by step how to do it
https://www.snbforums.com/threads/f...n-released-for-dsl-ax82u-and-dsl-ac68u.71980/
is this safe?
As safe as Asuswrt-Merlin firmware. This is an official port expanding the range of supported models.
Technically they can be different. If you don't trust the author, your options are to compile yourself, or check if the release was made from a ci action. Then you could check how the build pipeline looks like and on which commit it rat, showing you the state of the code at the time of the release. But I think even then they might be able to replace release assets
Ok thank you.This is an official port by a well known developer supported by both Asus and @RMerlin. The firmware image contains open source code as well as closed source code from Asus. This is not a hack or illegal port of Asuswrt-Merlin firmware. The GitHub page is GNUton's, he supports specific models Asus routers, receives bug reports and requests. It is safe to use and many folks around are using it. If you have any doubts about security - the choice is yours. It's an optional 3rd party firmware for your router.
Welcome To SNBForums
